Accessing ABS Sensor
allroy1978
I need to replace an ABS sensor on my right front. I have located the sensor and removed the bolt, but it doesn't move. Do I need to remove the disc/hub to get to it?
Thanks
I have same issue on my '96 4x4
HELP.. In the middle of this now..
I am replacing the front axle shaft u-joints and cannot get the ABS sensor off. The service manual is no help. I took the bolt out from the rear of the sensor and now it looks like I have to take the "protective" block off the front to get the sensor and spindle out. I do not see what is holding it all together now unless its years of RUST
After looking at pitures I tool (not allowed to post here), am I seeing a small (if so, what size)12 point bolt head that might be holding the "protective" block on??
pictures here
http://www.pbase.com/roycet4/image/116898618
http://www.pbase.com/roycet4/image/116898620
Thanks
Royce
It is simply rust and corrosion that is holding the sensor in there.
