Accelerator cable to carb
Fant
Went frm efi to carb on my 94 302.going in an85 ranger.what bracket can i use to hook up my stock accelerator cable to carb?am i pose to install the entire center piece thats got my bracket and all the vaccume lines thats between the carb and intake frm my 2.8 v6 to my 302 intake??? Or buy a bracket?plz help
Could you maybe ask all your questions in one thread instead of posting a new thread for every little thing that you think of?
I can for now on.thought it would be easier to do diff thread with each topic so nothing gets mixed up or ppl get confused. I apolojize
Trash the 2.8 bracket with the rest of the 2.8 and get a bracket off of a carbed 302.
The 2.8 cable will fit but will seem a tad too long... mine has been working for 2.5 years now.
I used a lockar cabel and bracket, remove the factory cabel from the firewall and use a warsher on both side to install cabel housing. Save the spring and plasic parts from the inside part of the factory cabel (what is on the inside of the firewall) on the inside of new cabel.
I ended up making my own bracket. I cut the holder part off my old 2.8 bracket and welded it to a couple pieces of flat stock, doing some measuring of where to weld, cut, etc... and it has been working great for me for almost a year.
Sent from my rooted SPH-D710 using Tapatalk 2
Kind of remines me of my alternator and power steering brackets off the 2.9 and made to fit the 5.0
http://memimage.cardomain.com/ride_images/1/3143/2241/7856120157_large.jpg
http://memimage.cardomain.com/ride_images/1/3143/2241/7856120156_large.jpg
http://carphotos.cardomain.com/ride_images/1/3143/2241/7856120180_large.jpg
http://carphotos.cardomain.com/ride_images/1/3143/2241/7856120181_large.jpg
i did the trying to put brackets together, just go to parts store and get spectre cable bracket 20$. can either use stock cable and drill a hole for bolt, i did that on one truck. or you can get there cable also, i have that on my 460 ranger. i can get a pic of what it looks like if you want. they mount using carb stud
truck build
http://www.greatlakes4x4.com/showthread.php?t=252764
I opted for a longer cable, turned a grooved wheel on the lathe. Well this is my setup.
NFEaRtL4-J1slSy9oqR4C0nBLOhKXa__uLQ6_3Zs-g=s140
