1988 2.9 sometimes hesitates on acceleration then kicks in a runs perfect.. complete tune up done.. cleaned throttle body.. looking for suggetions.. thanks ... mike
Try checking the throttle position switch (TPS) or just install a new one; sounds like there is a dead spot in it. Also, when you cleaned the TB you might have damaged the sensing wire for the TPS, they are very sensitive. I have also read other posts that have had initial issues after cleaning the TB then their truck started running correctly. Just do a search of this forum and you'll find some good info on this. Also, check out the tech section, lots of great info there. Good luck!
For
