Maxinstl
My AC compressor takes 10-15 minutes to kick on after my car has started. It works great once it kicks, but I don't know why it takes so long. The 2 pressure switches look fine, I've checked the low side pressure when running, it's 35 psi, it isn't crying when running, and its ice cold when its on. This is a consistent issue. Does this sound like a bad pressure switch? I've checked the low side pressure after the truck has been sitting a while off and it's about 135 psi, and when it (eventually) kicks on it drops to 35 psi. From my understanding that's normal. I don't want to change switches if that's not the issue, since you can't return them once you put them on...
Thanks!
Thanks!
