AC Refresh Help/Pointers
DeadEye200321
Forum Member
💻 TRS Socials
Arizona
AZ - USA
Vehicle
Drive
4" Super Lift
33"
Hey everyone!
I’m in need of some help, I am in the processor refreshing my entire ac system. I have replaced my ac compressor, condenser, and drier, and I flushing all my lines out as well as my evaporator out with ac flush cleaner, the new compressor I bought came prefilled with 7oz of oil, all the other components that are new I believe do not have any oil in them. Do I need to put oil in each component so they start with oil in them or just put the rest of the required 2oz’s of oil for a total of 9oz’s of oil in the compressor or a random line/component and once I run the system it will just even out? I can’t really find any information on the process of what to do when everything is replaced and drained of oil. If that’s not the case, should I drain the oil out of the compressor and put even parts of oil in each cleaned and new component? Let me know what you guys have done and what you think I should do, thank you everyone!
A shop manual would be your friend here.
The factory does have a process for oiling a repaired system. I don't have any manuals later than 1994, but this is the procedure from the '94 shop manual. At least, it'll get you pointed in the right direction' and maybe somebody else can post the 2004 oiling section.
Your charge weight should be on a sticker in the engine bay.
Notice, that the section addresses both R12 and R134a refrigerants; 1994s could come either.
I'm not sure if they still used R134a in the 2004 models, but I think so.
To do this right, my opinion, you need to pull a vacuum on the system before recharging.
First, when pumped down and sealed, to insure of no leaks.
Second, to remove all air and moisture from the system.
Think also about using a non-freon charge such as Enviro-Safe. Yes the stuff is flammable but so how is that worse than pressurized gasoline under the hood? I have found the propane based refrigerants to work well and the large molecules are less prone to leak.
