Made the swap today... Since the wrecked truck saw a lot of HVAC repairs in the last year and a half, I swapped a lot:
- Evaporator
- High pressure line (condesor to evaporator)
- Variable orifice tube
- Blower motor resistor (was replaced a month before the wreck, and the one that came out wasn't looking too good)
- O-rings at all connections opened (after a cleaning in alcohol and soaking in PAG oil, good as new compared to the 23 year old ones that came out)
I did not swap the accumulator, as the old one was actually rust free (on the sheet metal parts that matter) and unlike the wrecked truck (which had a bad compressor shaft and torn shaft seal), still had a little bit refrigerant pressure (and thus, shouldn't be saturated).
Basically, I replaced everything that was recently replaced and was compatible between the wrecked 3.0 and the running 4.0. Good thing I swapped high pressure lines, as the old one had 3 cracks in it.
Vacuumed it to 30 inHg for half an hour, let it sit for 30 mins (no movement of needles), then recharged it. Before final assembly, I added a few ounces of PAG oil to the accumulator, as a disproportionate amount of oil was lost in the high pressure line (which was dyed orange, not the usual yellow-green???).
The good news is she's running cold at idle and when running... at idle with the fan to low, the accumulator was frosted up. The bad news is on the way home from my parents' house (where my dead ranger lives), I got a lot of howing/fart can noise from the variable orifice tube (intermittent, possibly linked to compressor cycling?). No refrigerant smell in the truck either... and that's with all my AC serving gear/supplies sitting in the passenger seat.
Is such noise normal with a variable orifice tube? Or did I not charge it enough? Too much charge? I winged it a bit as I started with a partial can... Whoops?
