AC defrost issue
davebar
2001
OK, i tried a few ideas I found on the site, but didnt work.
My AC does not work and air only comes out the Def. 1999 B4000
I recharged the system, pressure was fine for about an hour. Everything work as it should, then back to not working. I charged again, worked for an hour and again, back to same problem.
The AC compressor will kick on for 5secs then off again.
I am alos getting a whining noise from the pass right tire area. I assume its the ball thing.
So, any ideas before I start looking at vaccum lines? Could it just be the ball is bad or the ac compressor needs replaced?
