Bronclow2
- Mar 23, 2009
- Automatic
I swapped a 2000 explorer 5.0 into my 99 ranger. The speedo and cruise are not working and it is shifting hard. The abs does work and my understanding is that the vss signal originates from there.
Live data on the scanner shows an accurate vss @the pcm. Could this be read from the oss or does it confirm that the abs/vss are working correctly?
I do occasionally have some abs codes: C1939, C1095, P0500.
My thought is the abs pump/module is bad, but the vss live data has me confused.
Thanks in advance
Thanks in advance
