ABS "ring" on front rotors???
gdk771
georgia
I ordered some new fron rotors for my Ranger and specifically selected the ones for 2WD ABS trucks. When I removed my old rotors, I noticed a "ring" with slots in it attached to the back side of the rotor that apparently triggers to the ABS sensor the speed of the wheel. My new rotors do not have this ring and when I contacted the vendor they had no idea what I was talking about. Is there any way to remove this ring without destroying it to install on my new rotors? They certainly look to be permanently attached.
Did you get just rotors, or did you get a hub and rotor assembly? That will make a difference.
But you can pound the wheel studs out of the hub and the rotor comes off separately.
I just ordered replacement rotors
Took the entire rotor off and there is nothing behind it? I thought a hub was part of a top hat type rotor? It is a standard spindle type rotor with the inner and outer bearings and the rear dust seal.
Yeah. I know this is true for the full size trucks, and I'm pretty sure it holds for the Rangers, if you pound the wheels studs out the rotor comes off and you are left with what amounts to a hub assembly. Has the spindle and the wheel hub and all.
Maybe on a dana44... not on a 2wd Ranger.
Heh, missed that part.
Yeah, that def doesn't apply to anything 2wd. They gave you the wrong parts and the goober you talked to at the manufacturer is just retarded.
So is anyone familiar with what I am talking about
on a 2WD model? I'm stumped on this one. I'll try to see if I can post a picture of the hub to show people what I am talking about and how it is mounted.
No need... Adsm was thinking 4wd, not 2wd.
You got non-ABS rotors, they didnt have the ABS exciter wheel on the back. Get the right ones.
I know exactly what you are talking about. By 96 rear wheel ABS was standard on Rangers and it didn't use the rings. Optional was 4 wheel ABS which required the rings on the back of the rotor. The rotors are sold both ways.
The ring can possibly be removed from your current rotor and installed on the new one. There is also a very, very good change that you will damage the ring in the process.
Your best bet is to take the rotors back and demand the correct rotors. Regardless of what the vendor you talked to says, they are available with the ring. He was just too stupid/lazy/ignorant to get you the correct part. Return these and make sure that you are clear that you need the rotors for a 2WD, 4 wheel ABS truck.
So are you saying they are not necessary on my 96?
I am confused now. I have a 1996 2WD Ranger. I don't know if there are ABS sensors on the rear but they are definitely on the front. Is it possible I have rotors on my truck that have rings that are not needed? I'll check the rear to see if the ABS sensors are present.
If you have sensors on the front you will definitely have them for the back. There will be only one sensor for the back; it is located on the top of the differential.
I dunno how to get that ABS ring off. Here's a photo. My '97 front rotor looks like this, even though I do not have front ABS, so mine has an ABS ring that's definitely not needed:
The rear ABS sensor is here, atop the rear differential. It's a black plastic rectangular thing with the black wire leading to it. It senses the ABS notched ring that's inside the pumpkin. I do have rear-only ABS.
I apologize I did not mean to make things more confusing. You say that you have ABS sensors on the front of your 96 Ranger, that means that you have 4 Wheel ABS. The rotors the store gave you are not for 4 Wheel ABS. You need to return the rotors that you have and make sure that they get you rotors for a 96 Ranger 2WD with 4 Wheel ABS. If they say that their is no such animal you need to get you money back and go elsewhere. Where ever you get them from check before you purchase them to make sure that they have that Exciter Ring. Hope that clarifies things a little.
Thanks everyone for the info...
I was given the wrong rotors. I sent them back and they found me a rotor with the correct ring on it. Mine looks different than the one posted by cvar however. here is what mine looks like. It seems Ford changed these rotor types around during the various years they made these trucks. I checked and found that I DO have the sensor on the differential as well so I have ABS on all wheels. At least I will know next time what to look for.
Hate to say we told ya so, but we told ya so. The ones cvar poster were for a 4wd Ranger, which is set-up a little different than a 2wd. I don't think the 2wd Ranger rotors changed much between 83 and 97 except for the addition of the exciter ring in 95+ models with 4 wheel ABS. There was a big difference between the 2wd and 4wd though.
For future reference Ford only had 2 types of ABS on Rangers. One was Rear wheels ABS, which just has the sensor on the differential, and was the only thing offered up till 95. The other was 4 wheel ABS, which has the differential sensor plus the front wheel sensors, this first became available as an option in 95.
