ABS light ???
95MEXIFORD
this may be a stupid ? but i thought my truck just had power brakes, not anti-lock. so what would cause the light to come on? and also, if the rear brakes where bad would it cause the truck to shake like a tire was blown?
Might have a bad sensor (located in the rear diff) or it could be a bad control module. Does it shake all the time or just when you hit the brakes? front rotors could be warped if it does it when you slow down.
