ABS light
LAndrus
99 Ranger XLT 4x4 3.0 V6
Had to replace my left front hub. All went well until I fired it up, the ABS light is on. Anyone have any idea why? Bad sensor on the hub?
Did you bang the sensor?
Did you forget to replug the sensor?
Is the hub an OEM quality (not a cheap chinese knock-off)?
^^On some cheaper built units, the ABS ring could not have the correct pattern
If to any of the above the answer is NO, check that.
If the answer was YES to all, light should come off alone after having driven a couple of miles. If not, get the ABS code scanned at your local Repair Shop.
I have a 999 Ranger XLT 4x4 Replaced a bad front abs sensor, Now what happens the abs light comes on after moving about 100ft, Does anyone have any ideas.. Thanks
