Abs light on
alson
Hello, i got a 94 2.3L 4x4. The ABS light came on, first I changed speed sensor,but that didn't help.Then got the light to flash for the code and got a code four.Replaced the RABS hydrolic valve and now instead of four, I get a code 12(low fluid during a rabs stop). After replacing the valve, didn't even need to bleed the lines. Brakes just as good as before. Any ideas? THanks.:
Fixed it!!! The contacts on the fluid reservoir switch were dirty. The switch comes off from underneath the reservoir and the contacts were then easy to clean.
