- Dec 10, 2021
- Washington
- State - Country
- N/A
- Other
- 2023 Taco
- Drive
- 4WD
- Automatic
If the front rotors are warped it can also cause a low pedal on first push of the pedal.
If there were air in the system... the pedal would always be low. It's not something that would be fine this time and not fine the next the brake pedal is applied.
The only thing I've ever seen that will allow the brakes to work fine this time and go to the floor the next is a master cylinder.
While that is true... the customer shows up saying my brakes are pulsing. Not my pedal is low.If the front rotors are warped it can also cause a low pedal on first push of the pedal.
When you hit the brakes and the pedal goes to the floor, you pump them and they start working,While that is true... the customer shows up saying my brakes are pulsing. Not my pedal is low.
If your parking spaces had better bump stops, my car wouldn't be in the waiting room right now.What is your first complaint to the mechanic going to be,
I'm not gonna argue...When you hit the brakes and the pedal goes to the floor, you pump them and they start working,
What is your first complaint to the mechanic going to be, remembering you just had the crap scared out of you?
1. pedal going to the floor.
2. pedal pulsing when stopping.
