wgt500
- Feb 9, 2010
- Automatic
Well, this is my first tech. post here. My son's 95 Ranger 4X4, (155000mi.) pulls to the right; however, it's not just a simple pull. When I spin the right rotor by hand there is excessive pad drag, (much more than the left side). When I retract the caliper pistons all is fine. There's residual pressure in the line. Here's the problem.The old calipers were leaking and I replaced them along with new hoses, (all three) and all new steel front and rear brake lines. Old lines were badly rusted. I replaced everything on the rear brakes. They were shot. The truck now stops great; however, it still slightly pulls right. When the brakes are applied the pull goes away. When the brakes are released you can see the steering wheel start to go right if you let go of it. The only component untouched is the ABS controller. Could this be the problem? Also has anyone converted ABS to non ABS. I could care less about having ABS on this truck. I think it's somewhat of a PIA anyway. I appreciate any help!
