austin
- Feb 1, 2009
- Automatic
i have a 2009 ford ranger 4.0l 4x4 and i have code c1237 rear wheel speed sensor signal fault. i replaced the rear wheel speed signal with a ford one and it did not fix it. my issues are that anytime im driving over 5 mph the abs motor is actuating and my brake pedal is really hard to push and can feel the abs actuating in the pedal and can hear it. all wheel speed sensors are reading equal mph with none of them dropping out. when i had my truck on the lift and ran it at 60 mph the abs never came on which i though was weird because anytime im driving it comes on. im out of ideas. any info will help need this figured asap!!! i live in ohio and with this weather i need the abs to operate properly!! thank you
