bsmithbyitch
i have a 95 2.3 ranger with the 5 speed tranny....a couple of weeks ago it started running like crap spitting, sputtering, trying to stall out....first i ran sea foam through it hoping that it would clean out anything clogging the fuel system. that didn't work. so i ran the codes. the only thing it said was one coil pack code and an engine temp. sensor that has been messed up for years. i replaced the coil pack (yes the firing order is correct)....STILL doesnt fix it. So i checked the fuel pressure..."running" the most it got was around 12 psi. I was told that it should be in the range of 30 to 45 psi. running and around 35psi. when not running. So i changed the fuel pump and it still is stalling out all of the time and sputtering
..i changed the spark plugs and wires a couple of months ago when i did a tune up. and now i checked to see if it possibly jumped timing, which it hasnt either.....if there is anything that you can think of PLEASE let me know its my daily driver and has to be running!!!!
Thanks.
Thanks.
