The truck pan won't clear the Ranger engine x-member and with a different pan you need to have a pickup that will fit the other pan. The pan you need is for a Fox body Mustang or a Crown Vic (79-93). You will also need a 90* oil filter adapter so the oil filter will clear the steering box.
Make sure you get either early Mustang Tri-y headers or Hedman 88400 headers. Stay away from the 89500's. They dump right into the passenger side I beam. I would also recommend getting a starter blanket and heat wrap for your headers - it will save your starter from being roasted by the passenger side header. There's about a thousand other little things that will crop up in the process but you can pm me if you're stuck. I'll help you out.
For
