about time
rangerjr
dallas,ga
its about time i could gt me a parts truck i got a 92 broco full size with motor and all to pull out and put in my ranger
You'll need a different pan and oil pump pickup tube as well as an oil filter relocation kit.
The truck pan won't clear the Ranger engine x-member and with a different pan you need to have a pickup that will fit the other pan. The pan you need is for a Fox body Mustang or a Crown Vic (79-93). You will also need a 90* oil filter adapter so the oil filter will clear the steering box.
Phil
Make sure you get either early Mustang Tri-y headers or Hedman 88400 headers. Stay away from the 89500's. They dump right into the passenger side I beam. I would also recommend getting a starter blanket and heat wrap for your headers - it will save your starter from being roasted by the passenger side header. There's about a thousand other little things that will crop up in the process but you can pm me if you're stuck. I'll help you out.
Phil
ok thank you red wont even be startin this till feb that is when ill have the money for the donor
