- Jul 28, 2013
- Manual
My 1992 extended cab 2WD Ranger is running and driving fine but the transmission is making a whining noise in the forward and reverse gears whenever the lock-up is not engaged (low speeds only).
After changing the fluid and filter, I still have the same noise. I think it must be the converter that is going bad because it only happens when the converter is torque multiplying.
I am wondering if the converter is easy to replace myself? I could probably unbolt the transmission an push it back a bit to achieve this but pulling the whole transmission is more work than I want to get into.
Is it possible to re/re the converter with the 2WD transmission still in the truck?
