Synchman
- Oct 6, 2007
- Automatic
I have a 1990 V6 4.0L with an A4LD tranny. After the truck warmed up, the reverse slips. No engine braking in first gear. It has had about 50,000 miles since a tranny rebuild.
I took it in to the dealer for a diagnosis. The diagnosis was tranny case worn out, need a new transmisssion for $2,785. This "diagnosis" cost me $200.
Since that was more than the blue book value of the truck, I took this to be an IQ test. I took it to a transmission specialist for a second opinion. Snohomish Transmission.
Snohomish Transmission pulled the pan off, and found the servo cover bolt sitting at the bottom of the pan. They replaced the servo gasket, O-ring, instaled the cover bolt, put in new filter, pan gasket, and ATF and test drove the rig. Problem solved for $200.
That was the good news... The bad news was that the axles were worn where the bearings ride. I needed new axles, which I had put in. And while they were in there, I had them put in a Detroit True-Track limited slip, and Amsoil synthetic. It is pretty sweet compared to the open differential I had eariler.
And I'm in discussions with the Ford dealer about them charging $200 for what I view as a wrong diagnosis.
Scott.
Scott.
