CarsonChris
- Apr 1, 2011
I've been reading as much as I can on the forum regarding the A4ld. The new BII isn't shifting unless I do it manually with the shifter. Then I have first and second. Won't shift in the drive position. If I'm in second and shift to drive it feels like it's missing that gear. The engine revs up to around 3000 rpms.
Would it be a good idea to drain the pan and change the filter? Does this ever help this problem or is it a waste of money?
I read in the tech section about an off road race A4ld. Is that only in the later models 90 and up or can one be made to achieve that with the 87 that I have? Sounds like the 90 and up have a computer control. Am I stuck using 86-89 A4ld because they aren't computer controlled for the torque converter lock up?
I hae zero experience with automatic transmissions.
