MountainRanger
Lastnight my a4ld took a crap.
Funny part was it worked fine before I went inside walmart i came back out started her up put it in reverse went right into gear like usual no noises no delay. put it in drive waited 4 seconds like usual and nothing reved it up still nothing shifted through all my gears still nothing (reverse still works fine). Thought ok low on fluid checked dipstick and its full. Fluid looked really dirty and i just serviced it 2 months ago so i pull the pan in Walmart parking lot drained all the fluid in the pan went in got 3 quarts and a can of that stop slip tranny crap. Reinstalled pan filled her up run it through all gears put it in drive nothing so i rev it up its starts to catch i let off and it engages it works fine nothing unusual drive home work fine while on hi way. Now everytime i put it in gear i have to rev it up to like 3 grand let off and tap the throttle a couple more times for it to go into gear (reverse still perfect) I seems like its low on fluid but its not.
Any info or help would be greatly appriciated
If i have to pull it im making sure another automatic will not take its place
