- Feb 7, 2008
- Automatic
Have an 89 Ranger Supercab with A4LD transmission, rebuilt about 20,000 miles ago, shifting fine. However I am experiencing leaks, one which I did some searching and reading about the slip yoke that goes into the transmission. It is definately leaking trans fluid into the u-joint that joins the slip yoke to the drive shaft. I was told the slip yoke is bad and needs to be replaced. I pulled it to look and it does not seem to have a hole or vent like some. It is definately not leaking from the extension housing seal, it is coming from the slip shaft internally into the yoke and onto the u-joint. Some advise to replace the slip yoke, others say it is actually a bushing inside the extension housing. Appreciate any input, tried to read the number on the yoke which appears to be 2249, the third digit very hard to read. I don't want to replace the slip yoke unless that would stop the leak. Also if anyone knows the Spicer number, or the specs, number of teeth etc.
Thanks,
Scott
Thanks,
Scott
