I'm not sure what exactly you're talking about, it sounds like you're confusing a couple things.
When you lift a ttb front suspension using springs or spacers, at some point you can no longer adjust the ball joints enough to get the wheels aligned. At that point you have to lower the axle pivot point. Some people have fabbed brackets, but most find it easier to just buy them. Some of the cheaper lifts use a steel plate to lower the axle pivot for the passenger side beam, but the often negative side effect is the bracket puts a hole in the top of the front differential.
Now that you've added a lift springs/spacers and lowered the axle pivots enough to get everything lined up, the steering geometry is all wrong. With the inverted Y that was used on TTB suspensions if you do not have this corrected enough you either have problems with toe-in on the alignment or horrible bump-steer... or both. So you need to either lower the steering box or use a drop pitman to flatten the steering back out. The stock pitman arm is cast iron, which is hard to cut and weld properly. An improper cut and weld means it will likely fail when you need it the most. Murphy's law. And if that happens on the road and you take out some minivan full of kids, some lawyer is going to roast you on a spit.
