I was doing my front axle and I began to wonder. Why cant wheel bearing grease be used on differential bearings and gears? To avoid the whole filling messy diff fluid thing?
the biggest thing (besides the pressure being a lot higer in the ring/pinion) is that the hypoid cut to gears produces a wiping motion accross the face of the gears -- any paste lube would work-away from the contact surfaces by the first revolution of the gear.
The splash-bath/climbing lube properties will "reapply" lubrication for each revolution of the gearset, so that it can be wiped again and again.
Additional benefits of a liquid lube is the related thermal mass and circulation/dissipation of heat.
Kinda stuff like that y'know ?
the part about the thermal properties of gear oil helping to cool the ring and pinion..... probably most important. go for an hour drive on a nice warm day, pull over, and put your hand on the diff cover, you might find it "kinda" warm, and thats with proper lubrication.
