A question?
Kevin Bullard
I have a 1986 Ranger standard bed 2.9 2wd . The questions are as follows
1 I have a 5sp in my truck now but what trans will fit without any problems
2 I have checked out the section on putting a 4.0 cluch on a 2.9 does include 2wd's
1 the old 2.9 a4ld, the 4.0 version of the a4ld thats it i belive
2 yea the cluch is the same for 2wd
will it a bolt on tranny or is there something I should look for
The M5OD R-1 from a 2.9L or a 4.0L have the same bolt pattern and will fit your engine. The 4.0L version has slightly closer ratio gears which I like on my 2.9L Ranger with stock tires and 3.73 rear end.
The 10" clutch upgrade worked out well for me. The 4.0L manual starter you need for the upgrade is beefier than the stock 2.9L version also. Make sure you get the 6 bolt fly wheel since they changed to an 8 bolt version in 97.
