just truckn
- Sep 21, 2008
- 2.9 V6
- Automatic
- Total Lift
- 6inch suspension 3inch body
- Tire Size
- 33 12.50 15
hello everyone in rangerland I need a little help im restoring my 90 ranger reg cab 4x4 i already have my frame and suspension done i removed my cab and fixed and repaired the rust but I also have to replace my rad support but I found out that my truck was damaged from previous owners and someone replaced the rad support once already but as I was working on it I found that who ever did the work really fd it up cause its not even fully welded in plus when I measured across from corner to corner its out an inchoose I got to square it up but I need to know if anyone else out there has there truck apart in the front i want to know what the measurements are for the rad support i don't trust what they r now after seeing the butchery they done plus I noticed that my rad support is tilted back i don't know if thats the way they r supposed to be so if anyone can give me some measurements it will b greatly appreciated thanks
