dmch82bl8
A few days ago I Swapped my messed up motor w/ a used motor of the same year. I finished the swap and primed the fuel system and it started up first crank. This motor runs much stronger than the old one. I've driven it around for a couple of days now, and this morning I had it idling in my driveway and it just died. Now it just cranks, but won't start.
I tested for spark w/ spark detector that goes between the plug and plug wire and lights up w/ each spark.....nothing. I checked the same way for spark from the coil.....nothing.
I referred to my Haynes Manual and tested the Primary and Secondary Coil resistance.....good. I tested Coil Voltage w/ ignition on.....good 12+ volts.
I even replaced the coil w/ different one, and same results.
Any ideas where I should go from here?
1994 Ranger XLT 4x4 3.0L Standard Trans.
Any help would surely be appreciated.
Thanks,
DMCH82BL8
Thanks,
DMCH82BL8
