Buggyman
- Dec 1, 2007
Sorry to keep posting so many questions.
I am about to put my 2000 3.0 flex fuel Vulcan back together. I pulled the heads and the machine shop is about finished, no cracks but the exhaust valves were trashed. Replacing the radiator, its full of sludge, along with most of the radiator hoses, they have 250k miles and they are full of crud. It has a new water pump, thermostat and I have cleaned all the coolent passages I can access on the lower intake. I am also replacing the synchro while its very accessible.
1. I replaced the syncro on my old motor about 6 years ago and I do not recall it being that hard. I have read all the articles but still had a few questions. Can I tell if my motor is TDC on the compression stroke with the heads off? Can I tell by which lifter is up? Ultimately, does it even mater if the motor is TDC if I align the notch that rotates with the vain of the syncro and mark this on the block and install the new synrco in the exact same alignment?
2. Instructions for Fel-Pro call for a small amount of RTV sealer on the lower intake manifold gaskets. What kind of RTV works the best and how much do you apply? Do you go completely around the gasket or just put a small amount on either side of the gasket? Do you use this also for the upper intake manifold and the valve covers?
3. Any advice on bolts for the exhaust manifold? I would like something that is less prone to rusting a breaking off in the future. Also any considerations when reinstalling the exhaust manifold gaskets?
Thanks for any advice,
Philip
Philip
