regulations stay the same from race to race as long as you stay within the same organization thats holding the race. if it were me i would get a beamed ranger (97 and older), throw a threat motorsports kit on the front with coilovers and possibly a bypass if i feel like a baller, with a giant motorsports 64" rear spring kit with their link killer shocks that were designed to use with those springs. i would then pay a reputable shop to build my engine, cab, and bed cages all tied in together. while the cage is being built, suspension can be mounted and shock mounts made so that you can maximize travel from your parts without running into clearance issues. one piece front fiberglass like you said, and fiberglass bedsides. theres a lot, and i mean a LOT of money into a race truck. even a 1450 truck which is the sportsman's class, is expensive. you need race seats, 5 point harnesses that are up to date, a fire extinguisher, spare rims and tires, spare parts, a race radio to be able to communicate with your pit crew as well as race officials, gas, entry fee, and a lot of other stuff i dont know since i dont own a race truck.oh yeah, theres also testing costs, money getting the shocks tuned right for each course, wiring it all, getting the bugs worked out so that it will run an entire race at WOT, and maintenance of wearable parts like heims, bushings, etc. a 4.6 v8 is a super wide engine. most common swaps into rangers are 4.0 SOHC, or a 5.0 v8 from an explorer. if you're set on doing the 4.6, it will be hard to squeeze it between the frame rails and still get proper shock angles in the front, without sacrificing travel by running a smaller shock.
the fastest way to $1 million in this sport is to start with $2 million.
wait, so the dixon bros 2WD LT kit only works for the edges with torsion bar suspensions? thats pretty dumb.. Because if edges have the same suspension set up, couldnt you use their 4WD kit?
its the same kit. it uses the stock spindle, so if you have a 4x4 all you need is longer axles to still be able to use 4wd
