getmoney06
- Feb 4, 2010
I have a few differnt issues wth my 2.9 its in a 1986 ranger its 4x4, 5 speed
1. im not sure if its the battery alternator or starter but if it sits for longer then two hours I need to jump it I was told my batter is good and i was told it could be a weak starter what do you think?
2 I cant go over 65mph when ever the motor is at higher rpms it stutters even at lower gears if I dotn shift right away,i was told could be sending unitfor the gas so I thought about pushing the clutch in and reving motor to see if it still did it and it doesn't, there is a leak on the top of the gas tank could it be sucking air??
