fordman49450
Hello, I have a 94 Ranger 4X4 ext cab with a 4.0, and a M5OD trans. I am going to have to remove the transmission. I know on others I have removed I Had to remove the exhaust cross pipe to get clearance. On mine I have a 3 inch body lift. I was wondering if anyone has removed their trans with a body lift to see if I still have to remove the exhaust or if I have enough clearance to where I dont have to worry about those manifold bolts. I havnt crawled under there to look and I was just wanting to know what you thought. Another question I have is I am going to either have to have my flywheel machined or replace it with a new one. I was just concerned if I have it machined will I have to add spacers to the flywheel so that it's back in the correct placement of the slave cylinder for travel? Thanks.
