8594
Man I need the frame specifications and all the Ford shop manual has is the body mount specs.
I do think that after all this time I just might have a grasp...
Just because something lived don't mean it wasn't imposable for it to have done so...
Ignoring the fact that after the lift it rolled on 40,000-miles...
Because I am out of ideas I started measuring.
I set both beams to the same height off the floor as measured at the steering arm. A little below ride height but equal.
I eyeballed both knuckles straight, not turned right or left.
I put a straight edge on the spindle pad and measured to a point on the frame that is about the same place on both sides.
In the semi-darkness I'm getting 5/8-inch difference, with the drivers side knuckle closer to the frame then the passenger side.
Moving the drivers side out would shorten the 15 3/4" number back towards 15 AND it would spread the slip yoke apart by the same amount.
It would also explain some other stuff that went on when the lift was installed back in 2003...
Wonder what Duff's warranty is on a screwed up drop bracket 5 years later?
