fartman
- Jun 6, 2011
- Automatic
I have a 96 Ranger with 2.3. The A/C has not worked in the year that I have owned it. So, I put a charge in it. I had to by pass the pressure switch to get the compressor to kick on then wnt on and started putting R 134 in it. At 1st 2 cans ( the small ones ) That din't do it! So, I got a big 180z can at NAPA. It sucks it right down. There are no leaks that I can see and even after the 180z can the gauge still reads 0 PSI. I used the stuff with red dye in it so if there is a leak it should be visable. The sticker near the engine says 2lb.'s. I find it hard to belive it STILL needs more. Any suggetstion??
