fiftyslost
- Sep 19, 2013
Hi all
I just installed A/C in a 98 2.5L that never had air (base model). I have all the components installed but not charged yet. There is no wiring whatsoever. In the dash or under the hood. I have a toggle switch that runs to a relay and from there it goes to the low pressure to the high pressure switch then to the compressor. I bypassed the 2 switches and the compressor does kick in. My concern is should I have run the ground wire thru the switches or is it OK to run the hot thru the switches? Or no difference?
Thanks for any help.
