A/C vacuum lines
tobyduck
Got to thinking hard about how to fix this problem. The A/C is stuck on defrost, I've had a lot of suggestions and the switch is not bad lol, leave some comments please!!!
the white line doesnt have anything connected to it and pulls a vacuum, the black line is connected into the vacuum system.
This is under the dash and everything seems connected and the other three colors (red,blue, and yellow) are connected under the dash
i dont know where the white line goes
I don't know the colors but there should only be one line from the firewall to the switch and then there are lines to the "doors" to open and close them. Defroster only is the fail safe the system goes to when there is no vac to the system.
In the past I have had a problem with a shotgun shell falling into the defroster and holding the door open..
Big JIm
invalid
invalid
album.php
picture.php
Under the hood
the white one comes form the firewall where the black one does. right above the fuel inertia switch. i forget where it goes but the black adn white one come fromt he smae spot on the fire wall
