ok, I haven't really worked on a A/C system since the late 80's when I was in school, then working for a company installing heatpumps, and servicing them.
That be typed, I have a 89 BroncoII, it has/had the R12, and the system was open when I got the BroncoII, so this week end I went to Knoxville, and bought a set of gauges, and a vacume pump,, I pulled my system in to a vacume and let the pump run all night, 7 hours, I then let it sit for 2 hours to see if it leaked out, and it didn't, so I go and start chargeing it with a 40 dollor retro kit
, right after the first can, the high side hose burst on me
, the hose in the past had made contact with the compressor and ate the hose a bit on the underside
, so I go out and buy a new hose, and while at the store, I bought a new accumalater/dryer, and orfice, r-134a oil, and all new o-rings, might as well do it right this time.
When I got home with my bag of goodys, I took my condenser out, and had it boiled clean at a rad shop, and also picked up a few cans of flush out, after cleaning out the evaperator, and the remaining hose's, I installed the new orfice (the old one was clean), reinstalled my condenser, then installed the new accumalater (spelling sucks), then pulled the system down into a vacume over night again, then let it set for two hours checking for leaks, I went to set up to gauges and found out I couldn't use the high side gauge
, the retro piece was on the old hose, and does NOT want to come off
, so I charged the system useing just the low/suction side, my system will get cool, but not cold, for some reason I couldn't get the suction side over +6 degree on the 134a gauge, my father-in-laws system was low and I charged his to +15 and it will freeze you out, but I first put in 3 can's, this to me seemed like too much
, but it sill wouldn't go past +6 degrees
, and when I picked up the RPM's to 2k it would pull down to 0 to -1 degree, now this isn't in a vacume, I put a 4th can in standing back, wondering what was going to blow first, hose or compresser
, I have been running it like this for a few days, and like I typed, it gets cool, but not cold, I know it won't do as good as a 134a factory system, but I think it should do better.
does anyone have any ideas
what could be going on with this and the low suction side
?? I know the gauges are good, I had theem checked with the guy I use to work with backin the late 80's, he said for a 50.00 set they where pretty darn good, and on the money with the set he has that he paid 250.00 for.
Robert
Robert
