A/C plug?
6.2
Rural Manitoba, Canada
An way to put an AC plug in? I wanna put my old ps2 in my truck do I can use it with my new 7" DVD/stereo.
The headunit has the hookups for audio/visual, all I need to figure out is how to power the PS2.
Any ideas?
Harbor Freight has convertors for cheap!:icon_idea:
Or hooking up directly to a battery. You can run it much nicer by running 12v power from the battery into the cab where you have the Power Inverter hooked up. I had a switch on the dash hooked up for mine so I could flick it on and off. Worked pretty well for my laptop.
Also, the power inverter is about the size of a bible usually and can range from 25-95 depending on power.
(Bibles are usually pretty uniform in size *shrug* thats why i chose that)
