ForOffRoadDriving
im just throwing ideas around in my head about my project truck and i was wondering, did ford make a 3.0l w/o ac? i want to eliminate my a/c but leave the compressor on so i can use it for onboard air. is this a worthwhile idea? i assume i would need to find a way to supply oil to the compressor so it doesnt seize up. i want to eliminate that cluster f*** that is on the passenger side of the engine compartment and replace it with a simple non a/c heater box. that would make gaining access to the right side of the motor that much easier. any body see anything that i have over looked or any reasons that this wont work? also, ive heard that if your a/c doesnt work that your defrost wont work right in the winter? is this still true if you completely eliminate it?
