ranger hans
- Jun 12, 2015
I've got a 1988 Ranger with the 2.9 V6. My problem is that my A/C is blowing hot air, but there is a charge of R-134a in the system (it was converted many years ago and has worked on and off since).
The compressor was replaced about 3 years ago and I believe a few other components are new to system as well, circa 3 years ago. The compressor is turning (not just the flywheel, but the compressed clutch is engaging), but the air coming from the vents isn't getting cold. I know that freon is circulating because when I put a gauge on the low pressure side, it would jump from high to low as the compressor cut on.
My first thought is a bad expansion valve but wanted to run this by you guys to see if anyone else has had experience and wisdom to share.
