Joe Bob Biggs
- Feb 9, 2012
Help is much needed.....
I am in the finishing stages of my 5.0 Conversion and have a problem. The truck started as a 98 3.0 Ranger w/ 5 Speed. I am putting in a 5.0 HO dumped the FI and going Carb'ed. When I removed the main Harness from the Power Distribution on the Fender to the Puter I marked all the wires I thought I would need. Oil press, Temp, Alt, A/C, Coil. ...... So we went to clean up the harness such as cutting out the Injector Plugs and CPS and such. My buddy helping me may have went a little to Cut Happy cause I have a mess of wires on the floor. Now the Key wont start the truck. I know that most likely the Clutch Switch was cut-away and I can get that figured out. But what I am wondering is how much stuff actually needs to run through the Puter to operate. I know basic wiring and am going to run a new relay for the Fuel Pump and try to run the key switch to the Clutch Switch to the Starter. Am I going to run into any other Puter Dependent item such as Speedo does it use the Puter?
