99 ranger scab, left frt half shaft
jrboatin
NorthWest Indiana
Hello all,
Hope this is the right place for this...
I have to replace my left front 1/2 shaft. I did not see anything in tech file on this. What should I expect at the hub and once I remove knuckle assembly from shaft does the shaft just pull out from axle assembly ?
thanks
You will have to remove your hub and the plastic snap ring inside. Then the caliper and caliper mount. Vacumn and abs wire(if you have 4 wheel abs) Tie rod and ball joints to get the spindle off. Then the shaft will pull out of the differential. You may have to use a scredriver or small pry bar to get it out.
