BlueLighting1999
Do you need two locker or only one??
Do they make Locking hubs for a 99 4WD XLT Ranger?
Your question is a little confusing. Are you asking about locking hubs or lockers in the differential?
Yes, they make manual hubs for the 98-01 rangers. They are called AVM hubs. I have a set, and they work very well. They sell in pairs at about $100
As far as 1 or 2 locking hubs, it depends on what you have in the front differential. If you have a locker up front, you could use either 1 or 2. If you have open or limited slip differential, you need 2 hubs.
You can have any combination of lockers between the differentials. The truck you ask about has an LS in the rear, and an open up front. (I have the same truck model.)
woah buddy...you dont have a clue what youre talking about eh? that link you posted is for an eaton posi (limited slip).
On each side of the front axle, there is a hub....this will connect the tire (one per side) to teh front axle. These are called manual hubs.
As you are 4wd, you have an axle in the front, AND one in the rear.
What he was saying is that you can put whatever you want....either a locker in just the rear, or just the front, or both.
Its up to you.
