99 ranger face lift
it definitely looks better dirty doesn't it? That was only two little puddles worth. The full widths are working great.
I cant keep mine clean ether, every little puddle gets the truck dirty.
But it does look good dirty!
Poser shots!
Damn it! Look at that big ass bear spot behind the axle. I need to get that fixed.
You also need to box that upper track bar bracket in!! :shok:
Also, I would remove one of the upper "short" links on your front axle. You'll gain more flex as having both of those uppers binds the suspension.
Other than that, it looks great.
ehh, you think so? I thought about it. I've hammerd on it pritty good already I don't think its going anywhere. Its easy enough to do though. ADD IT TO THE LIST!
Trust me. Been there, done that... It sucks.
I have been told before to remove one of those top links and it would handle better too. when I get the driveline in and take it wheelin thats probably what I'll do.
Looks good! Got some pretty good flex their!!
Got any better pics of your doubler linkage? I'm still crawling under my truck to shift into lo-lo....lol
if those rear 4" springs are deavers use them. they flex like crazy
I will take some pics for you when I get a chance. its a pritty simple set up.
started to build some rock sliders. I just need to paint and install them. I didn't do anything too fancey but they should work for me.
my work space is getting a little crowded
Those rock rails look really good! Any luck with the front drive shaft?
