99 ranger 4x4 not working, flashing 4x4 lights
dean-93
just bought a 1999 4.0 5 speed ranger 4x4 ,and the 4wd will only work after i reset the battery/computer after i reset it i can go to 4hi to 4lo to 4h again but when i try to go back to 2wd it only works like half the time and if it dosent work the hi and lo lights flash and then i half to reset the battery again to get it out .
my abs light is also on if that could be related,and the interior binging noise goes off while driving sometimes.
i would think the wiring is fine since it does work sometimes but i dont want to waste 100$ buying a shift motor and that not being the problem.
thanks for your help
also forgot to mention i went thru all the fuses.
i also found a relay box under the dash near the gas pedal do these have anything to do with 4wd.
changed my shift motor and its been working so far.about 80$ at orileys lifetime warrenty
