smog exempt state so, not sure what i need to do here …
SCTx4 kam reset base 87 tune
getting codes p0171and p0174, truck running like absolute garbage.
sounds like piston slap timing retarded to -2 at one point. 4Low would engage
cleared tune.
before running the tuner to richen up WOT , getting code P1131 desc. lack of HO2S11 switches - sensor indicates lean see P2195
and p0171 - no description available. trucks windows and 4wd low wouldn’t work.
ran tune with 4% richer at WOT , got some power back , not a lot .
not sure if 4wd low is working since i flashed it on the highway and haven’t retried
popping codes P1151 and p0174 .
Map is within parameters
could it be TPS, or is this all emissions related.
cleared tune.
