99 gauge cluster
h82w8
replacing bulbs in instrument cluster and now indicator lights on right side won't light. can anyone post a wiring diagram or link? thanks
Did you replace with regular bulbs or LED'S? If you used LED'S, make sure you didn't put them in backwards.
Sent from my SM-G920V using Tapatalk
regular bulbs, tested each before i installed. it's only the indicator bulbs on the right side. i figure it's got to be a common hot or common grd. my chilton manual doesn't have the diagram
