99 explorer wipers wont work and interior lights wont work
ksvtwin
indiana
have an odd problem with my stock 99 explorer. when I open the doors, the interior lights stopped coming on. the lights DO come on when I use the dash switch though. the front and rear wipers stopped working at the same time. also the front and rear washers stopped working. the key no longer "dings" when left in the ignition. the wipers don't even "click" when you try to operate them. all other features still work fine. I checked the fuses and swapped relays . didn't help does anyone have any ideas ? I appreciate your advice very much. kent
Welcome to TRS :)
While Rangers(what we know about) and Explorers 1991 to 2001 are similar they are not the same
Yes, most likely problem will be the GEM, its the body computer and controls wipers and door open sensors
Not sure where that is on the 1999 explorer, in 1999 Ranger its behind the radio
You can download 1999 Explorer owners manual from Ford site, its free, and it may tell you which specific fuses are common to GEM and these devices, there should be 3 or 4 fuses and the Battery Saver relay, if its similar to Rangers
