Hello forum fellas im new here so hopefully im doing this right. I have a 96 ford explorer 4.0 ohv when it is cold it fires right up but instantly dies unless you hold it half throttle or more. When you do that it reaks of raw gas and spits anf sputters, kind of sounds like its cammed for about the first 30 seconds its running. After that it runs perfectly fine. Once you shut it off it will fire back up fine but if it sits for a couple of minutes it does the same thing.
I've replaced the o2 sensors, tps, maf, plugs, wires, coolant temp sensor, and a few other things.
It has a - P1000 code (obd2 system checks incomplete) and a P0402 (EGR excessive flow detected)
I ran some test with the snap on scan tool and the egr valve sounds like it is working.
Im kind of at a loss as of now. I haven't got a chance to leak down test or compression test it but im curious about that EGR code. Would that cause it to flood out if that is not working on cold starts?
Engine has 95k miles on it and no fluids are mixing
