Wolfe
- Jan 16, 2011
After purchasing a 99 troy lee Mazda b3000 the clutch started making a whooo noise while i was releasing the clutch through the friction zone. At first I thought it was the pedal making the noise as it pivoted because it was very quiet. Now that I've moved to a more hilly area the noise has become much more profound due to the higher load I put on the clutch while trying to start from a stop. So the higher the rpms, the louder the whoooo noise. It will make the same noise through 2nd gear. Once the clutch is all the way disengaged there is no noise. Any ideas on what this could be?
My first guesses where glazed clutch, pivot bearing or throwout bearing. However I now dont think it could be the later two since the noises they make dont really match up to this one.
Now for the brake question. Recently I replaced the front and rear pads on my truck, and all was good for the first 4000 miles. Now the pedal has a little play but once the brakes engage, THEY ENGAGE! The front wheels will very easily lock up and slide. There is no abs light on and all the fuses are in place? Im going to take my wheels off and check to see if anything obvious is wrong. The fluid is full as well.
Any help with either of these would be fantastic. And its a great little community you guys have going here!
